100% Secure Shopping 100% secure shopping
Reliable Warranty Reliable warranty
Shipping Included Shipping Included
EcoFlow DELTA Pro Ultra 60 kWh / 90 kWh (installation included)
Costco Price
Promo Price
$32,299.99
Promo Price
$32,299.99
Costco Price
$38,999.99
Sold out
per
  • 7.2kW-21.6kW output with up to 3 inverters.
  • Up to 90kWh capacity with 3 inverters and 15 batteries
  • 5.6kW-16.8kW solar input with up to 3 inverters
  • Online UPS, 0-ms transfer time
  • LFP battery
EcoFlow DELTA Pro Ultra 90 kWh (installation included) Includes:
  • 3x EcoFlow DELTA Pro Ultra inverter
  • 15x EcoFlow DELTA Pro Ultra Battery
  • 1x EcoFlow Smart Home Panel 2
  • 2x EcoFlow Power input/Output Cable
  • 4x EcoFlow 400W Solar Panel
  • 2x Solar Extension Cable
Model
  • EcoFlow DELTA Pro Ultra 60 kWh (installation included)
  • EcoFlow DELTA Pro Ultra 90 kWh (installation included)
Project consultation recommended prior to ordering.
Click here to get a free quote.
Click here to learn about the order process. **Service currently available in California, Florida, Georgia, Maryland, Missouri, New Jersey, New York, North Carolina, Pennsylvania, Texas, and Virginia. More regions will be coming soon.
Customer reviews
4.0 563 Reviews
  • 5 star
    75%
  • 4 star
    60%
  • 3 star
    10%
  • 2 star
    8%
  • 1 star
    1%
Reliable warranty
Shipping Included
The most powerful whole-home backup solution.
Month-long power security, 6-90kWh Capacity
One unit covers every appliance, 7.2kW-21.6kW, 120V & 240V Output
With a 7.2kW output, EcoFlow DELTA Pro Ultra effortlessly runs even energy-hungry household items, like a 3-ton central air conditioner. For more power, pair 3 inverters with the EcoFlow Smart Home Panel 2 to unlock a 21.6kW AC output. Plus, with X-Fusion you'll get a constant 7200W output no matter what.
One hour of solar for one day of power, 5.6kW-16.8kW Solar Input
By leveraging High and Low-PV technologies, a single inverter sets new portable solar input standards with a 5.6kW input. Connect three inverters for a monumental 16.8kW, gaining a full day's home energy in 60 minutes. Whether you prefer a portable setup or a rooftop solar system, you can achieve true energy independence.
You won't even notice the grid was down, 0-ms Downtime, 0 dB Silent Backup
Imagine a world where power outages go unnoticed. With EcoFlow DELTA Pro Ultra's online UPS, you'll get just that. With uninterrupted power flow, EcoFlow DELTA Pro Ultra safeguards your vulnerable electronic equipment round-the-clock. For extended outages, you don't want to hear your backup in the background, so for low draws under 2000W*, it's completely silent. With a whisper-quiet 0 dB, your nights remain undisturbed as it powers your devices. *For a maximum of 30 minutes.
Peace Of Mind With An Advanced Design: EcoFlow X-Cooling
Peace Of Mind With An Advanced Design: Boost Performance with BMS
Our state-of-the-art LFP tech and advanced battery management system (BMS) regulates vital data, ensuring the safety, longevity, and high performance of EcoFlow DELTA Pro Ultra.With each battery offering a cycle life of 3500+, you'll get years of use before capacity drops to 80%. Even then, it keeps powering on.
Powers through the most challenging situations
Installation Consulting Service For EcoFlow Smart Home Panel 2
With our service, you'll experience a seamless EcoFlow Smart Home Panel 2 installation.We connect you with a fully-trained local electrician and provide tracking from order to fitting. Our team is on hand to answer any technical queries, ensuring a smooth, hassle-free setup that prioritizes your convenience and satisfaction.
• Charge faster with high 400W solar input • Up to 23% conversion rate • Durable, multi-layered materials • Self-supporting with an adjustable angle • IP68 waterproof rating • One-piece folding design • The solar to XT60 charging cable is included in EcoFlow portable solar panels
A lithium ferrous phosphate (LFP) battery is a type of lithium-ion battery known for its added safety features, high energy density, and extended life span. The LFP batteries found in EcoFlow’s portable power station are quickly becoming the leading choice in off-grid solar systems.
LiFePO4 first found widespread commercial use in the 1990s. Since then, prices have dropped enough for the average consumer to use the technology in most of their battery-powered devices. LFPs are less prone to fires and thermal runaway when compared to Li-ion batteries. Unlike lithium-ion, Lithium ferrous phosphate batteries are also free of unethically sourced nickel and cobalt, making it the go-to choice for many energy storage applications.
Specs - EcoFlow DELTA Pro Ultra
Each battery: 6144Wh, 102.4V⎓60A
60kWh Combo: 6144Wh*10, total 61440Wh
90kWh Combo: 6144Wh*15, total 92160Wh
AC Continuous Output
7200W
AC Surge Output
10.8kW
Scalability
21.6kW
IP Rating
IP54
Battery Cycle Life
UPS
AC Output (Each inverter)
DC Output (Each inverter)
12.6V⎓30A, 378W Max
AC Output Socket (Each inverter)
2 x 120V, 20A Max per port(Backup UPS)
1 x 120V/240V, 30A Max(Backup UPS)
2 x 120V, 20A Max per port(Online UPS)
1 x 120V, 30A Max(Online UPS)
USB-A (Each inverter)
USB-C (Each inverter)
AC Input (Each inverter)
Solar Charging Input (Each inverter)
Total 5600W, 2 ports
Inverter Dimension
Inverter Net Weight
31.7 kg (70 lb)
Battery Dimension
Battery Net Weight
50.7 kg (111.8 lb)
5-year warranty
Connection
Bluetooth & Wi-Fi & 4G
Discharging temp
-20°C to 45°C | -4°F to 113°F
Charging temp
Storage temp
Specs - EcoFlow Smart Home Panel 2
Weight
52.9lb(24kg)
Dimension
32.4 x 14.9 x 6.7 in. (823.7 x 379 x 170 mm)
AC voltage (nominal)
120V/240V
Feed-in type
Split phase
Maximum current rating
100A panel / 90A storage
Busbar rating
120A
Maximum input short-circuit current
10kA
Operating humidity
Up to 100% RH, condensingMax
Number of load branches
12
Communication
Ethernet, Wi-Fi, Bluetooth
Specs - EcoFlow 400W Solar Panel
Net Weight (lbs)
35.3lbs
Net Weight (kg)
16.0kg
Net Weight (lbs) With Kickstand Case
41.9lbs
Net Weight (kg) With Kickstand Case
19.0kg
Dimensions (inch)
42.0 x 94.1 x 1.0 inches
Dimensions (cm)
106.8 x 239.0 x 2.4 cm
Rated Power
400w
Cell Type
Monocrystaline silicon
Efficiency
22.6%
Connector Type
Solar Connector
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
12 months
Operating & Storage Temperature
−4°F to 185°F
Manual
Paper IconEcoFlow DELTA Pro Ultra User Manual
Paper IconEcoFlow Smart Home Panel 2 User Manual
Paper IconEcoFlow 400W Solar Panel User Manual
